I’ve recently had several conversations with the seller of a Garrett powered propjet. The price is very attractive, as is the appearance.
There’s quite a story that goes along with it. If you are considering this aircraft, it would be well worth your time to consult me prior purchase.
Cheap Garrett Powered Propjet
Jeff, is there a link you’re referring to regarding the Propjet project?
What is the difference between the IV-PT and the propjet?
It’s a different name for the same aircraft. My guess is the term “Propjet” was borrowed from the Piper pre-Meridian PT6 conversion STC, and it just stuck. As far as the IV-PTs go, there was no official name differentiation between the Walter, PT6, or Garrett-powered airplanes.George Wehrung wrote: ↑Thu Sep 26, 2024 8:07 pm What is the difference between the IV-PT and the propjet?
JC. I believe Piper called theirs a “JetProp”.
Jeff, I stand corrected.
