Jacking solution for ES
DrewDickinson
Please share your very best solution for lifting the ES mains.
I remember Lancair had a small bracket solution years ago, that attached to the main gear axle area.
Ideas / suggestions appreciated.
thanks - Drew Dickinson
Drew, have you checked for the jack attachment? Most ES builders made a mount that is usually in the cargo area under the foldaway floor. I can take a pic and upload so you can see mine. I believe some owners have had aftermarket ones made. I think Bob Pastusek or Matt Speare would know.
Matt Speare
Drew:
You can get the ES adapter thru Unionfab.com by creating an account and submitting a quote to purchase from a previous order: Order ID: XJ20240306-9678358659-2. With shipping it was around $200. You likely only need one, as you probably aren’t going to have a need to jack both sides at the same time. The wheel fairing needs to be removed to utilize. A few pictures of what it looks like and how to use it below.
DrewDickinson
Thanks all for the assist here.
Matt's source (unionfab.com) was able to resurrect the previous order and is going to produce.
Landed cost is roughly $200 bucks for a single. Their rendering attached.
I am ordering a single
ES Jacking Point.png (87.33 KiB) Viewed 10123 times
today, if anyone else needs one of these, let me know and happy to tag it on to my order.
Ryan - you bet, this will be an easy "must take with" item that will stow nicely in the baggage compartment. My hanger neighbor saw me lifting the airplane for a new W&B, and said..."so how you going to do that if you are away from here" - which provoked this search.
Appreciate all the help here guys - Drew
