Replacement Fuel Caps/Improved
Kevin Eldredge
Hello,
I had to develop replacement fuel caps from my G4 project and have found that many Lancair's use similar fuel Caps. I have a made a limited run of these improved fuel caps if anyone finds themselves needing replacement! During redevelopment we took a few liberties to improve the design to make them easier to open once adjusted to fit tight. Check them out here: https://www.gryphonaerosports.com/
Kevin, those look great! Are they milled from aluminum or cast?
Kevin Eldredge
All the parts are milled from 6016 t6 solid aluminum.
Kevin Eldredge wrote: Tue Jan 14, 2025 5:06 pm All the parts are milled from 6016 t6 solid aluminum.
That's awesome. PM sent.
