Stable jacks are essential for safe maintenance of Lancair landing gears. The 320/360 sits too low for may standard jacks, and the 235 is even lower. Standard tripod jacks often interfere with the inner gear doors. The solution is these custom-made jacks to fit the LNC2 series.
Secure sturdy jacks built to fit the standard jack points of a Lancair 235, 320, or 360.
Fits under the jack points without interfering with the inner gear doors.
Width is adjustable to fit the jack points on your airframe. The contact pad swivels about 10 degrees to align to the curved belly pan.
Automotive scissor jacks are welded in place and easily fine adjust the height and level, never sag, and never leak.
During construction, these jacks are handy because the fuselage can be precisely leveled, and then it stays there.
Plastic feet are suitable for smooth epoxy floors, and are removable for use on rougher surfaces.
$500 per set. Specify whether you have the 1/4" hole for alignment to the fuselage belly, and choose white, black, or another color.
Shipping is typically $150 in the continental US, and about $250 for Europe.
There's a review of the jacks embedded in the video:
Jacks for Lancair 235, 320, 360
- RobertDevine_YouTube.jpg (52.13 KiB) Viewed 108 times
- LNC2_Jack_Pack.png (6.73 MiB) Viewed 108 times
- 20240412_145015.jpg (2.79 MiB) Viewed 108 times
- 20240213_125812.jpg (2.5 MiB) Viewed 108 times
Bob's jacks are great, super simple, nothing to go wrong or leak. 100% recommend.
Those are INCREDIBLE!!
Thanks for posting the info on them and awesome video.
