Jacking the airplane securely is a necessary part of every (annual) Condition Inspection. Keep the airframe stable with these easy-to-use jacks.
Secure sturdy jacks built to fit the standard jack points of a Lancair 235, 320, or 360. Fits under the jack points without interfering with the inner gear doors. Width is adjustable to fit the jack points on your airframe.
Automotive scissor jacks are welded in place and easily fine adjust the height and level, and never sag. Plastic feet are suitable for smooth epoxy floors, and are removable for use on rougher surfaces.
$500 per set. Specify whether your aircraft has 1/4" alignment holes for jacking.
Shipping is typically $150 in the continental US, and about $250 for Europe.
Jacks for LNC2, 235/320/360
