Aro-tek hydraulic cylinder
Gary,
It looks like you are missing the shaft seal.
This link might be useful in general for cylinder work.
https://www.n91cz.net/Hydraulics/Rebuil ... inders.pdf
Note that I now use ball cylinder hones on cylinders.
The seals are available from many outlets. I have used www.theoringstore.com
The part numbers vary by source, but tend to identify seal type and size: ID, OD and thickness.
Note that main cylinders also have a sealing washer under the piston nut.
Also, note that early cylinders used a simple washer under the snap ring. Newer cylinders use a machined endcap that physically trap the snap ring so that it cannot slip out.
I sell a convenient kit for these, has been very popular:Gary Martin wrote: ↑Wed May 07, 2025 11:55 pm I need an O ring for the top of an Aro-tek hydraulic cylinder for a 360 nose gear. Any ideas?
https://odaydesign.com/product/700-0072/
