In search of a CD316-02 Door Handle Spindle for ES
Matt Speare
In search of a CD316-02 Door Handle Spindle for ES. The external door handle tension 6-32 has broken within the spindle and don’t know if I can remove it with a screw extractor. Painful
Matt,
Not sure if you got this resolved or not. I may have that inside door spindle part that you’re looking for. But I’m not sure. You may be able to remove that screw by getting a fine pair of needle, nose, pliers, and reaching inside it and screwing the screw through The spindle. Another words keep trying to tighten the screw and it may go that direction versus trying to back it out with a broken off end. And that you were using the threads that are already sticking through to the inside to keep turning the screw.
