Landing gear hydraulics.
Have a question or are stuck, ask here
Treemanfrom57
I have replaced all hydraulic hoses on my 320. What is the best procedure for bleeding the air out of the system? I swung the gear yesterday and am getting inconsistent behaviors. The common theme seems be burping! My guess is the air is/has made its way up to the pressure shut off switch. Thanks, Kevin
Generally it’s to get hydraulic fluid pushed thru the system under some amount of positive pressure from the lowest point and bled from the highest point. I am not quite sure about the 320 system without seeing a hydraulic schematic.
