Hydraulic Valves
Posted: Sun May 19, 2024 1:16 pm
My hydraulic pump has started to short cycle, cycles about every 45-60 sec. Inspection shows no external or internal leakage, however after some experimentation, turns out it only cycles about every 5-6 min airborne with the gear handle UP. Flap position does not seem to make a difference. Seems to me a good place to start is the gear valve, I'm thinking it's by-passing internally. It could be an actuator bypassing in the down position, but I think that would more likely show up as a leak.
Consulting the build manual all it shows is the gear and flap valves bolt onto the central valve body with o-rings sealing the mating surfaces. I did not build this plane, nor have I ever had a reason, up till now, to access these valves. Question for those familiar with these controls: Can the gear and flap valves rebuilt, or just replaced? Can they be rebuilt in the field or need be sent off somewhere? Any "gotchas" associated with removal/installation?
Thanks for any input.
