IV-P Flat Tires
Posted: Mon Oct 21, 2024 7:54 pm
So, I’ve owned my IV-PT for 4 years now and have had 3 flat tires, all on the Main Gear. Each time there was a small tear in the tube, (probably due to pinching, and yes I talc the tubes well).. I’ve been flying for a good while in many types of planes, and I’ve never seen this level of tube failure even though I would re-use tubes through several set of tires, (years), with good results. A 600X6 tube is listed as suitable for the 600X6-15 tire in Goodyear manuals.
A couple of questions for any IV owners.
1. Have you noticed an abnormally high rate of failure in the MLG tubes?
2. If you look hard you can find tubes listed as 600X6-15. Anybody ever bought one and is it indeed a distinct size? Do they perform better the straight 600X6 tubes?
3. Has anybody used the “GOOD”, (expensive), puncture resistant tubes? I assume they are a thicker stronger material, which I would think would contribute to any pinching issues. Am I wrong and are they worth the price?
Feed back welcomed.
Feed back welcomed.
