Going to have all the cylinders overhauled as I have three or more pushing oil out of the crank case. I know i know, Mike bush does not recommend engine tops. But when you are getting 1.5 hours per quart of oil I have to do something.
Does anyone know of a good jig to use to keep the case under tension worth the cylinders pulled?
