TKS Fluid Tank on IV / IVP / IVPT
Want to show off your work, or document a build? Post here.
I am not sure which sub-forum topic this would be most appropriate, so I will post here and provide a link back to here under the IV/IVP/IVPT sub forum as well. I recently had a request for information and pictures on my TKS fluid tank reservoir for my deice system from Jeff Edison. I spent some time compiling and texting 30+ pictures with descriptions hoping that may be enough data for him to decide if this path is an option. Within a couple weeks I have received two other requests for the same info, so I am making a thread, with the pictures and details for anyone inquiring, about this option for TKS fluid storage on a IV. I have completed this method of fluid storage on two IVPT's and found the capacity (4.5 - 5 gallons), the weight and balance (very close to center CG, but a bit forward which helps most IV's), the filling method, and the ability to drain the system during non-icing seasons make this installation fairly handy. The down side, it's much easier to install while building, although not impossible for a conversion on flying airplanes.
The original Lancair Builders Manual designed a raised floor under the rudder pedals which was essentially wasted space in the cabin. On both IVPT's I installed storage tanks on, they had already fabricated the raised floor per the manual. I removed that system and installed pre-preg for side and top panels, using the existing floor and exterior fuselage sides as and bottom of the tanks. I created a smaller area behind the lower quadrant support as the suction bay of the tank system. That area also served well to install a forward external drain (in the nose wheel well). The top close out for that area also became the the mounting area for both TKS pumps. I was told the TKS pumps like it better being lower than the pumps, but that wasn't practical. Having the pumps just inches from the fluid in this design has worked just fine, but initial operation and bleeding requires fluid in the filler tube to be higher to create the initial gravity feed of fluid until air is purged. A note here; those pumps will burn up in seconds if run dry. Ensure (in any installation) you push fluid into the pump BEFORE running the system. TKS doesn't rebuild them cheaply!
Initial Cleaning of floor area for tank installation
TKS 1.jpg (724.61 KiB) Viewed 9847 times
Area between hydraulic valve support and firewall for pump main draw sump
TKS 2.jpg (487.17 KiB) Viewed 9847 times
Cutting our filler door for TKS Fluid fill point
TKS 3.jpg (343.64 KiB) Viewed 9847 times
Installing pre-preg and ramped area for foot rest/TKS Fluid storage tank. Note pre-preg support and fluid pathways for center tank area where pump will be located.
TKS L-side Fluid Tank Initial.jpg (768.22 KiB) Viewed 9847 times
Pump is mounted on the center section top close out panel
TKS Pump Mounted on Tank Top Panel.jpg (569.33 KiB) Viewed 9847 times
Filler bucket mold (styrofoam) before carbon lay up's, to be installed inside fuselage behind filler door
TKS Filler Bucket.jpg (549.7 KiB) Viewed 9847 times
Main pump mounted and close out top panel bonded in
TKS Main Pump.jpg (634.88 KiB) Viewed 9847 times
Windshield pump mounted on other side of main pump
TKS Windshield Pump.jpg (775.16 KiB) Viewed 9847 times
TKS Filter mounted on back of hydraulic pre-preg vertical support member
TKS Filter.jpg (748.41 KiB) Viewed 9847 times
Note short suction line going down into the tank within inches of main pump
TKS Suction line to Main Pump.jpg (518.02 KiB) Viewed 9847 times
TKS FIller Bucket inside view, recess for rudder bellcrank.jpg (1.08 MiB) Viewed 9840 times
TKS Outside view Filler Bucket with rudder bellcrank recess .jpg (1.06 MiB) Viewed 9840 times
TKS Filler Bucket showing rudder bellcrank clearance.jpg (721.31 KiB) Viewed 9840 times
TKS Filler bucket & Door Lid sealed.jpg (440.68 KiB) Viewed 9840 times
TKS Filler Door on completed plane.jpg (448.68 KiB) Viewed 9840 times
TKS L-side Fluid Tank Initial.jpg (768.22 KiB) Viewed 9840 times
TKS L-Tank closure with Hysol after tank sealed.jpg (725.52 KiB) Viewed 9840 times
TKS R-Tank top closure Hysol added.jpg (1.97 MiB) Viewed 9840 times
TKS R-tank closed.jpg (2 MiB) Viewed 9840 times
TKS Tanks finished with CF Bids on seams.jpg (754.65 KiB) Viewed 9840 times
Admin
Site Admin
That's a slick way to add tanks! Ya'll are making good progress.
